DTC U0001-81 from multiple modules
Hello,
I have a 2014 with a CAN BUS issue is appears. Attached my Autel scan report. Car drives fine and randomly the dash lights up with errors for ABS, stability control, power steering and more. Power steering is noticeably not working during the error. After 15-20 minutes the problem goes away.
The errors are intermittent.
I am getting DTC U0001-81 from the following modules:
TCM (Transmission Control Module)
PBM (Parking Brake Control Module)
TCCM (Transfer Case Control Module)
CHCM (Chassis Control Module)
CHCMB (Chassis Control Module B)
I'm also getting code U0415-08 from the PSCM (Power Steering Control Module)
Battery appears to be good, otherwise the Autel would have told me. I still have to check the fuses.
Could it be as simple as bad contacts? from corrosion or something?
Any ideas would be more than welcome!
Thanks,
Andreas
Thanks,
Andreas
Hello,
Thanks,
Andreas
Thanks,
Andreas
Gargar1970
Jul 29, 2024 02:05 PM
Sportysport14
May 4, 2024 01:19 PM
