How To Install Front & Rear Dash Cam in Range Rover L405: Video write up
Hello everybody! Purchased our 2021 Range Rover full-size about a month ago and just got around to installing a dash camera in the front and rear. The front was pretty simple, however the rear was a bear to get a clean install. I recorded the process with a 4 part series. First video is just an unboxing of the dash cam. I went with the BlackVue DR900X 2 channel. 2nd part is tapping and routing power from the fuse panel behind the glove box, up the A pillar and to the mirror. 3rd video is installing a custom made BlendMount and mounting the dash cam. Check out that video for an explanation on the custom part. Apparently the mirror stem must've changed for 2021. The 4th video is installing and routing the rear cam through the tailgate all the way back to the front.
The following 2 users liked this post by krazyk86cu:
DiscoNight5 (08-25-2021),
Groucho123 (08-05-2021)
krazyk86cu (08-05-2021)
Thanks! I’m pretty handy with mods but this one definitely had me nervous at first
Groucho123 (08-09-2021)
krazyk86cu (08-09-2021)
Groucho123 (08-19-2021)
They installed mine yesterday, they did say the didn't use the fuse tap as they felt soldering in was a better option. They ran late as I had a couple other issues to fix while it was in and didn't charge me for the install.
Thank you for the videos, they actually used them at the dealer.
Now I will watch the video on the use of it.
