Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
L405 Wheel Knuckle Bearing install problem
Old Mar 15, 2023 | 10:47 AM
findre's Avatar
4wd High
Default L405 Wheel Knuckle Bearing install problem
Has anyone successfully pressed a knuckle spindle bearing. Bought the big Meyle bearing and its making noise, replaced it and new one is noisy too. Done many bearings before on other things, but this one seems "special". Removed knuckle and used a press.
Old Mar 16, 2023 | 09:37 AM
findre's Avatar
4wd High
Correction, the new bearing is totally trashed. Wheel wobble. I spoke to a reputable shop and they said Meyle bearings maybe defective because, everything I explained that I did to install was, right on. I am going to switch to LR bearing and see if that solves the problem.
bobbybuchan
Discovery Sport
Nov 3, 2022 02:23 PM
b c
Feb 2, 2012 07:25 PM
NiveK1970
28
Nov 24, 2009 11:41 PM
bhowell
Mar 25, 2009 01:10 AM
