Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
Thumping noise from rear suspension
Old Aug 19, 2024 | 12:46 PM
mrmiller835's Avatar
8th Gear
Originally Posted by pal
i have a 2017 range rover autobiography lwb that has the exact same noise as you described by quickserv.
I really appreciate if you help me to understand what was the issue and how did you resolve it?
Hopefully it is not the differential.
Regards,
Old Aug 19, 2024 | 12:47 PM
8th Gear
I'd love to hear the follow up on this from anyone that can help. My 2018 Range Rover Autobiography LWB is having this exact issue.
Old Aug 19, 2024 | 01:01 PM
8th Gear
Did this work?
Old Aug 19, 2024 | 01:02 PM
wcc18999's Avatar
I would definitely have your differential checked. Some folks changed the differential fluids and that seem to resolve the noise issue. Good luck.
Old Aug 19, 2024 | 01:09 PM
8th Gear
Thanks, I have had my differential fluid changed and the guy said that sometimes does the trick. It did not solve my issue however. Wondering if its the lower arm ball joint?
Old Aug 19, 2024 | 01:25 PM
wcc18999's Avatar
Some people changed the diff fluids multiple times and got lucky with the noise, but it took more than one fluid change. Seems strange, but definitely cheaper than swapping the actual diff. Have an independent tech put it up on a lift with the car running in gear to see if you can pinpoint where the noise is coming from.
Old Aug 19, 2024 | 01:33 PM
8th Gear
Thank you, will try that.
Old Oct 12, 2025 | 11:32 PM
thebruce's Avatar
Any definitive info on this? My wife says she hears this in the morning when starting slow from stop light on our new 2020 but im unable to reproduce it.
2020Defender1stEdition
Jan 17, 2022 09:55 AM
PaulLR
Feb 27, 2021 09:09 PM
Echoman
Apr 23, 2014 07:20 PM
sickws6
Oct 3, 2013 04:26 PM
gsgtsg
Dec 14, 2007 12:40 PM
