Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
2001 RR P38 - Key Fob Malfunction
Old Jul 26, 2020 | 08:44 PM
HugoFirst's Avatar
4th Gear
Exclamation 2001 RR P38 - Key Fob Malfunction
Is there any hope out there? I replaced batteries on my key fob and confirmed it does not work. My rover keeps locking me out which is common when the key fob does not sync. I've looked everywhere to order a new key but it has been challenging. I'm looking for options and was curious to know what current owners have done? Also, what you guys think of the following:
1) BeCM SyncMate to bypass the alarm.
2) Any auto-technician services out there that can repair the circuit board on the key fob.
3) Is this the end of my P38 if I can't get a key fob to sync to the alarm.
4) I called an auto-locksmith and dealer but awaiting to hear from them tomorrow.
Any input would be greatly appreciated. Within reason, cost is not an issue. I just want to know what works in this case.
Hugo
Old Jul 30, 2020 | 12:32 PM
keninnc's Avatar
Are you located in the USA.
If so the fob uses 315mhz signal.
Land Rover quit making these fobs.
There is only one place you can get a replacement.
https://crnw.co.uk/index.html
I got one from them in early 2019 and still works great for my 2001 P38.
Is your BeCM in "Engine Disable" state? or is everything working fine but you just want a fob
Old Jul 30, 2020 | 12:34 PM
keninnc's Avatar
Also,
Synch mate will not bypass the alarm or immobilizer.
When you say the door locks lock you out can you expand on this. You may have a broken door actuator with a broken microswitch.
Old Jul 30, 2020 | 09:44 PM
HugoFirst's Avatar
4th Gear
Originally Posted by keninnc
Also,
Thanks Keninnc for the inout! I'm looking into the door actuator as well. But, I'm also having technician look at the circuit board on my key fob....there are some mircoswitches that are not working properly. I'm located in Florida, USA. Will look into your link regarding key fob. Much appreciated mate! Hugo
Dave03S
Jul 30, 2020 05:12 PM
BelGSX-R
May 4, 2020 11:31 AM
eitydeuce
Jan 30, 2020 11:40 AM
Veronica Mora
Dec 10, 2018 04:19 PM
Coyote
Jul 2, 2013 09:33 AM
