Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
99 range rover 4.0 SE Suspension Help
Old Aug 3, 2020 | 06:49 PM
1999landrover's Avatar
Default 99 range rover 4.0 SE Suspension Help
Had my local mechanic change out the suspension from the EAS to a standard coil suspension. Having issues with the front driver shock, whenever I drive through a pot hole or bump it clunks really hard. Thinking I need to change the shocks since it has some regular shocks from O'reilly, I don't believe that the shocks were replaced from EAS to standard coil suspension. Any suggestions on the model/catalog/brand that I should be looking for? also should I also need to change the back shocks as well?
Thanks
Old Aug 4, 2020 | 03:44 PM
Fastercat's Avatar
Ideally you want shocks made for the coil suspension, front and back. Check your bushings and sway bar links for the sound. Make sure there’s a rubber spring isolator on the coil to the frame mount. Also check the condition of the bump stop. They can deteriorate to almost nothing, especially if they are ever driven on the bump stops much
dlong85
Feb 2, 2020 01:42 PM
pilsner
Sep 25, 2009 01:48 PM
financialwiz101
Jul 12, 2009 03:11 PM
oliveoil
Jan 30, 2009 08:29 PM
chelo
Apr 13, 2006 02:11 AM
