Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Any experience with replacing motors in P38 door actuators?
Old Jul 13, 2023 | 10:04 PM
PNW_Boxer993's Avatar
3rd Gear
Default Any experience with replacing motors in P38 door actuators?
Research found on D2 with dual motors, has anyone attempted to replace on P38? Advice with best aftermarket motor to purchase with correct length arm and polarity? Any assistance much appreciated. Thank you!
Old Jul 14, 2023 | 11:49 AM
Harvlr's Avatar
I replaced my RH Fwd one with one I robbed from a spare rear door. It was a bit fiddly but not difficult.
Old Jul 14, 2023 | 09:51 PM
3rd Gear
Thanks Harvir. In lieu of spare, we would like to purchase Mabuchi motor and retrofit. We may need to purchase a couple of options and figure it out. Anyone use a Mabuchi FC-280pc-22125 for both driver and passenger actuator on a 1999 P38?
Old Aug 3, 2023 | 09:38 PM
SamP38's Avatar
First time poster here - just came across your thread when looking for other door latch info!
I have bought some electric motors from Ali Express to suit the central locking on a VW Passat / B5 golf, which match up in terms of form factor. They were cheap as chips, and I've installed one with success so far, you just need to carefully remove the plastic cog from the shaft. Hope this helps, I can post a link to the item if you like. Sam
psteff
Build Threads
Feb 15, 2020 06:11 PM
zaman
Jan 30, 2020 09:11 AM
Pardue
Aug 28, 2015 03:09 AM
pizzaboy
Jun 19, 2012 06:59 AM
westarv
Dec 21, 2011 07:46 AM
