Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
P-38 electric issue
Old Jun 4, 2018 | 06:29 PM
koimaster's Avatar
Default P-38 electric issue
Just parked the l322 and got the old P-38 up for the summer time. As is typical for this truck I have owned for 20 years now there is always an issue.
Right now the center console switches do not work. Cannot get the mirrors to move nor role the windows up and down. Anyone have any ideas before I run this off a cliff?
Old Jun 5, 2018 | 06:10 AM
Fastercat's Avatar
Did you check the fuses?
Old Jun 5, 2018 | 11:11 AM
koimaster's Avatar
I did check them. According to my manual it is fuse #22 in the interior right side. 30 amp fuse and it looked good. Thought it might be something else like a relay but the manual is pretty limited.
Old Jun 5, 2018 | 03:01 PM
Fastercat's Avatar
If you have or can borrow one use a test light and see if there power at the fuse.
Old Jun 6, 2018 | 03:52 PM
Jim Geisler's Avatar
I had to buy that center unit with all the switches and replace it and all worked again.
Old Jun 15, 2018 | 12:09 PM
koimaster's Avatar
Really? Crap that is a drag. Apparently there is no power to the switches but if I put the rig into reverse the mirrors change to backup mode.
Old Nov 2, 2018 | 05:16 PM
Blofish's Avatar
3rd Gear
Had the same problem with fuse #22 every once in awhile would pop the fuse. Found the puddle lights at bottom of the doors witch I didn`t know were there had fallen complete apart and wires were causing a short in interior lights. I changed my lighting to LED and could not figure out where the other bulbs belonged thus the puddle lights hard to new and pricey a little solder and plexi glass they look and work great.
stillruns
Mar 7, 2019 08:54 PM
melias
LR4
Feb 6, 2019 07:08 AM
JUKE179r
Sep 5, 2018 10:58 AM
Ry0ishikawa
May 29, 2018 02:03 AM
94mattda
Mar 26, 2009 06:34 AM
