Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Steering wheel
Old Jan 17, 2021 | 05:57 PM
Blofish's Avatar
3rd Gear
Default Steering wheel
Going to u-pick yard tomorrow have to have all the tools when I arrive to remove steering wheel. Anyone know the torx sizes for backside bolts and large nut size off hand ?
Old Jan 19, 2021 | 12:36 PM
keninnc's Avatar
Torx is 25 or 30
Big nut is 19
You may want to bring a drill with a small bit. The steering wheel needs to be turned to get access to the torx bolts.
Removing the cover of the drive shaft with the Phillips screws will expose a hole just below where the key goes in. If you drill out that pin you can remove the ignition and then will be able to turn the wheel.
toofaroffroad
Apr 17, 2020 03:23 PM
No Doubt
Jul 18, 2019 04:44 AM
eitydeuce
Apr 6, 2018 05:23 PM
bmeier
Jul 26, 2014 08:10 PM
Turtlep
Nov 8, 2012 02:39 PM
