Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Sunroof Closure
Old Nov 17, 2020 | 12:42 PM
Darin Olson's Avatar
Default Sunroof Closure
Just recently the sunroof on my 2001 RR quit rocking up in the back to seal. It also will not rock open from the back. The motor is working, but the back will not lift. Any suggestions would be appreciated
Old Nov 17, 2020 | 09:25 PM
Harvlr's Avatar
I'm pretty sure the chintzy plastic tracks are broken. This is a very common problem on P38'S. Unfortunately, to fix it properly isn't cheap. The proper fix is to replace the two track assemblys, which are expensive. You can try to find good used ones. Also, there is a seller on eBay who 3d prints the plastic pieces that break. I haven't read about anyone having good success with these (including me). I ended up manually getting mine closed and disabling it. I may someday fix it, but not in the near future. There are quite a few threads on this topic on rangerovers.net
Old Nov 25, 2020 | 08:13 AM
keninnc's Avatar
Someone sells all the individual parts on ebay. Pulled from working sunroofs. Cheaper than buying the entire track. FYI the track has to be removed regardless if you buy an entire track or just the parts. Land Rover does not sell the individual parts
https://www.ebay.com/itm/Range-Rover...gAAOSwwL5fuWso
cvhyatt
Dec 29, 2019 12:10 PM
jamestfl
Apr 11, 2019 03:14 PM
Hedleyj
Jan 19, 2010 03:24 PM
And4848
Dec 10, 2008 02:40 PM
TrickyWhu
Mar 9, 2007 11:38 AM
