Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
timing chain replacement specs (60D V8 4.6 Liter Engine. 2001)
Old Yesterday | 03:30 AM
Martin G's Avatar
5th Gear
Default timing chain replacement specs (60D V8 4.6 Liter Engine. 2001)
On my P38
60D V8 4.6 Liter Engine. 2001.
I m looking for the timing chain replacement specs
I took off the front timing cover, to replace that Notorious Seal. ERR7280
Endless coolant dripping.
While i have this open,
Looking at the sprocket wheels and chain.
I feel the timing chain is a bit loose / slack.
How much play is normal since there is no tensioner?
Anyone has some experience?
I dont see the timing chain replacing specs in the Rave Service manual.
++Chain length in mm...?
++Or free Angle play (degrees) of the crankshaft rotation?
Any info would help.
Thanks Martin
Vtobin
Range Rover L405 (Fourth Gen)
Nov 11, 2022 06:29 PM
SWAINROVER
Mar 18, 2016 05:26 AM
arod829
Oct 10, 2012 12:08 PM
Satisfying Pie
Dec 5, 2010 09:13 AM
RED
Apr 30, 2008 11:37 AM
