Range Rover P38 (2nd Gen) Talk about the Land Rover Range Rover P38 within.
Tire recommendations
Old Dec 30, 2020 | 06:09 PM
Blueknight's Avatar
6th Gear
Default Tire recommendations
Hello, I'm buying a 2000 Range Rover and it will need tires. I live in S. Utah and will do a combination of street driving and some trail riding with it. Any suggestions? Thanks
Old Dec 31, 2020 | 10:17 AM
Harvlr's Avatar
Unless you will carry a spare tire outside of the space designed for it, you need to keep the stock sized tires. Any larger tires won't fit the space, and with the All-Wheel-Drive with the viscous coupling, you should not run a smaller spare tire than the installed tires.
My P38 came with a very good set of All-Seasons, and they work surprisingly well off-road, because the P38 is so good off-road. I plan to go with BFG TKO All-Terrains when mine wear out. I have them on my Disco and they are really great tires. If you aren't doing any realy serious off-roading, a good set of All-Seasons will work well.
Old Dec 31, 2020 | 10:35 AM
Blueknight's Avatar
6th Gear
Thanks for the reply. I've been talking to a few tire stores and that's the tire they are all recommending. I'll buy these tires. Thanks, Bob
johna16
Oct 10, 2020 07:06 PM
jrncsmith
Oct 11, 2019 07:09 AM
Willie00d2
Nov 14, 2010 07:11 PM
Spike555
Mar 20, 2009 07:18 AM
NewRoverOwner
Tires
Mar 11, 2009 08:01 AM
