Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
2005 RR HSE - ignition key lock, but resetted after disconnecting the battery
Old Jan 7, 2023 | 04:51 PM
invisible's Avatar
Default 2005 RR HSE - ignition key lock, but resetted after disconnecting the battery
Hello everyone, looking for advice.
Recently 2005 RR HSE developed an ignition key lock problem - the first time it happened when car was left outside with 10F-20F night temperatures outside. I did some reading and it is not a steering column problem - if I disconnect the negative feed of the battery, and connect it again, I can turn the key but I don't want to do it all the time. If I remove the key with 50% chance it will be locked or not, so I now leave the key in the ignition all the time, which obviously is not a solution.
My question is - how do I fix the situation permanently or semi-permanently? I don't want to take the car to the dealer because I know that they will tell me it is a steering column problem with $5000 repair tag.
P.S. I live in Reno and unfortunately there are no reliable LR/RR specialists around.
Thanks in advnace
Paseka
Range Rover P38 (2nd Gen)
Aug 31, 2022 01:21 PM
Cozzer
LR2
Sep 11, 2016 07:55 AM
liPPy
Dec 30, 2010 02:49 PM
jkid
Jan 28, 2008 09:53 AM
