Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
2010 3.0d EGT Issues
Old Nov 12, 2024 | 03:26 PM
J15CK's Avatar
Angry 2010 3.0d EGT Issues
Hi everyone
im getting codes for a fault with my EGT. Checked the live data and its showing 1000c on this. am i right in thinking this is the green egt sensor pre DPF in the centre section? Ive ordered LR015454 as a replacement. Code was P2031-00, P2084-00
also had a load of codes came up before I parked it up for this
P244B-68 Permanent - DPF pressure too high.
P045F-77 Pending - EGR B - Control stuck closed.
Booked in to have an EGR delete once the
P00BE-00 - Pending - Mass/Volume air flow B air flow too low
P2297-00 - Permanent - OX sensor out of range during deceleration Bank1 Sensor1
P0235-94 - Pending - Turbo Boost Sensor A curcuit
P004D-77 - Intermittent - Turbo Boost Solenoid B - Circuit High
P0121-86 - Intermittent - Throttle Peddle Position Sensor A - circuit range/performance
P2262-22 - Pending - Turbo Boost System Performance
anyone had anything similar? after any information please to point in my the right direction. had a new engine 6k ago and turbos were placed.
GavinC
May 9, 2026 08:48 AM
