Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Coolant leaks from both driver and passenger side
Old Sep 22, 2024 | 10:09 AM
nilut21@gmail.com's Avatar
Default Coolant leaks from both driver and passenger side
Small drips are running from both driver and passenger side. The leaks look to be coming from two black chamfered rubber pieces. Can anyone help identify those parts?
Update: I found the two pieces to be rubber and to be part of the cabin temp sensor module (
Part Number:5h2219874ab)[size=16px]. They open up very easily and so I can see the coolant dropping consistently. My question is - are they supposed to be dripping coolant like that by design, and if so what causes it? Should I replace the temp sensor module completely?[/size]
Coolant system only holds pressure to -10kPa inHg under vacuum, instead of -25.
Already replaced cross over pipes, water pump, pcv valve, thermostat housing.
Last edited by nilut21@gmail.com; Sep 22, 2024 at 11:58 AM. Reason: More diagnosis
Crumpler
Discovery Sport
Jan 29, 2024 11:29 AM
stevevetter
Nov 22, 2022 11:00 PM
ZGphoto69
Oct 10, 2022 10:59 PM
astromikan
Aug 8, 2021 08:39 PM
WarrenZ
Sep 25, 2016 05:26 PM
