Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Ecu/ecm Headache
Old Feb 9, 2022 | 04:55 AM
Striker's Avatar
Default Ecu/ecm Headache
I need help 😫. I am working on a Range Rover HSE with bad ECU. I bought a used one from ebay to replace the bad one. I tried so reprograming tools, none of them worked. Please any suggestions will be greatly appreciated. I am trying to be cheap by doing it myself....lol
Old Jul 19, 2022 | 09:23 AM
sam4927's Avatar
5th Gear
Did you got the same part #? what tools you have or what tool you trying to program it with ?
thanks
Old Jul 20, 2022 | 03:06 PM
Striker's Avatar
Yes. I bought the right ECU part number. I have tried Launch and nanocom diagnostic equipment. Yet, it tells me Ecu is not programmed to car.
Old Jul 27, 2022 | 08:02 AM
sam4927's Avatar
5th Gear
hi, if depends on the wiring diagram you have good power,negative and good HS CAN and you able to connect with the ECU by your OBD scanner , so which gonna help you SDD or try to clone that original one on bench if you have hexprog or flex ...etc
thank you
Moretti
Mar 29, 2024 02:03 AM
arains44
Jul 11, 2021 11:21 PM
Olvera97
Sep 10, 2019 12:54 AM
willys_49
Nov 10, 2012 07:42 AM
JRdisco1
Aug 25, 2005 03:07 PM
