fault code vmd_dtc_00003.rex
Hello fellow Rover Genius,
Battery terminals shorting/hard reset(with batt disconnected) to clear ECU memory...
It would be good to know before atempting to hard reset the HVAC computer and not mess anything up.
At the moment the HVAC recirculation/fresh air in damper motor is not working, i can see the door is fully open and not moving when i press the recirc button on the dash with the pollen filter is removed from the housing.
The fault code from the scanner is: B1083 , fault code vmd_dtc_00003.rex
Please advise when possible.
Thanks in advance.
Thanks in advance.
mtate315
Aug 2, 2024 08:26 PM
