Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
fault code vmd_dtc_00003.rex
Old Apr 2, 2020 | 05:57 PM
JabiRover's Avatar
5th Gear
Default fault code vmd_dtc_00003.rex
Hello fellow Rover Genius,
Battery terminals shorting/hard reset(with batt disconnected) to clear ECU memory...
It would be good to know before atempting to hard reset the HVAC computer and not mess anything up.
At the moment the HVAC recirculation/fresh air in damper motor is not working, i can see the door is fully open and not moving when i press the recirc button on the dash with the pollen filter is removed from the housing.
The fault code from the scanner is: B1083 , fault code vmd_dtc_00003.rex
Please advise when possible.
Thanks in advance.
mtate315
Aug 2, 2024 08:26 PM
bebushka
Feb 18, 2020 11:02 AM
e36m3
Feb 11, 2014 10:45 PM
tweakrover
Jul 9, 2009 09:13 PM
stevey88
Apr 3, 2009 11:03 PM
