Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
GAP IIID tool suspension trouble shooting
Old Aug 27, 2021 | 12:32 PM
safiaka's Avatar
Default GAP IIID tool suspension trouble shooting
Hello Landies,
My suspension on my 06 supercharged ranged rover is failing. This week it dropped to bumpers. I am trying to use the GAP tool to diagnosis the source(s) of the problem. After pulling the R7 fuse in the engine bay fusebox, the suspension will hold for about 18 hours. After that time drop is starting to be noticeable in the driving. Putting the fuse back in, the air compressor will return the height to the normal. I started to make some plots of the variables to locate the problem. What variables should I start to test to locate the problem?
My exhaust valve is opening while the compressor is running on startup. Is this intended to purge water or a problem?
Thanks
File Type: pdf
bmdubbs
Apr 7, 2021 01:26 PM
A_roblessed
Jan 15, 2020 04:56 PM
cmshoot
Nov 16, 2019 07:53 PM
jbullock78
Oct 19, 2019 10:41 AM
squish
Dec 12, 2017 02:37 PM
