Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Help please
Old Mar 22, 2021 | 01:46 AM
Kalani0115's Avatar
Default Help please
Hi We bought a 2008 range rover sport from someone and did not realize that the heater core was leaking coolant onto the floor cause a can bus problem. Randomly my care will have TPMS fault and the light will come on, the hazard lights start blinking, car will lock and unlock, and the radio says system shutting down. I read that this could be a cluster issue however I am leaning more to the wires on the passenger side floor because they were soaked with coolant. I have cleaned everything multiple times with electronic cleaner and even took out the transmission control module as well and cleaned it and the same thing still keeps happening. I not there is a connecter that I move will sometime cause it to happen and when someone is sitting in the passenger seat seat it will happen more frequently, but when I take the seat out and mess with the wiring the car does not ever want to do it to me. Please help me I am so frustrated and lost about this issue. Thank you.
Old Apr 1, 2021 | 03:33 PM
rodin66's Avatar
3rd Gear
Hi I had this happen when back in my P38 days -- Carpets were soaked -- turned out I went under the car and using a straitened coat hanger cleaned the AC drain ( you will get wet doing this ) -- I suggest you research this - it might help you
Philip Chan
Nov 6, 2019 08:03 PM
Philip Chan
Jul 26, 2019 01:33 PM
twr7cx
May 10, 2015 02:40 AM
indytruth
Nov 16, 2011 10:02 AM
hammbone930
Dec 24, 2008 07:09 PM
