Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
I need some help i am in a stuck loop
Old May 6, 2025 | 06:12 PM
paul battaglia's Avatar
Default I need some help i am in a stuck loop
Hi, my name is Paul I work with the owner of Outback garage in Bayshore. I have recently bought a 2007 Range Rover sports supercharged. I have done some harness repair to the transmission harness connector located behind the battery on the passenger side. I have replaced both rear Heights sensors, both front and rear valve blocks along with the front driver side bag I had blowout on me after I finally got the front end to raise. It blew out the driver side front and now it says it needs another rear left height sensor. I don’t see any wiring that is damaged and I can’t really find any connector locations online. I was wondering if someone can provide me with some other locations of where it could join where I could have either some higher resistance due to water damage a pin that has pulled out that’s occasionally making contact or break in a wire I really would like to keep the air suspension, but this really does have me in a loop
all help is appreciated
CantComplain
Jan 18, 2024 04:31 PM
Frank4
Dec 1, 2022 09:12 PM
Ben Ledbetter
Mar 31, 2021 12:35 PM
LR-CAN
Nov 23, 2020 09:39 PM
Ataylor88888
Aug 16, 2020 04:45 PM
