Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Supercharger knock
Old Oct 10, 2022 | 02:53 PM
2013RRSSC's Avatar
Default Supercharger knock
I'm new to the forum but own a 2013 Sport Supercharged that I bought new. It has ~135k miles on it and has generally been a good car. I noticed knock in engine and thought it was time to change the timing chain. Independent shop diagnosed it as the supercharger that needs replaced. The quoted replacement cost at $4k parts only and `$5k with labor. I'm seeing supercharger kits online for much less, but there may be something I'm missing. My question is whether this is reasonable or should I go elsewhere? Any thoughts would be appreciated. Thanks
Old Oct 14, 2022 | 11:17 PM
salvine's Avatar
Be sure it's not just a warn coupler. 30 dollar part the goes between the pulley snout and SC. The SC does need to be partially removed to remove the snout and change it. I did mine as preventative when I did the chains.
Old Oct 15, 2022 | 05:36 PM
2013RRSSC's Avatar
Thank you. I will look into it. It is a noticeable knock at idle, but is otherwise running fine.
spinach_e
Aug 13, 2022 11:58 PM
LRD2Dave
Jun 5, 2020 06:26 PM
rhyslegge
Feb 19, 2020 10:29 AM
ShaggySE7
Nov 25, 2016 09:58 AM
targotsi
Feb 18, 2009 05:58 PM
