Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
Trans won't shift into 5th & 6th gears on its own
Old Jun 6, 2019 | 05:45 PM
alyn123's Avatar
Default Trans won't shift into 5th & 6th gears on its own
Have a '06 Range Rover Sport with 131,000 miles. Trans shifts smoothly and used to shift up to 6th gear on its own.
More recently it stops in 4th gear, going down the freeway at 3,000 RPM. You can take the shift lever left to manual and push to the + and upshift to 5th (2,500 RPM) and then to 6th (2,000) RPM and it will stay in 6th until encountering a hill and downshifting itself. It will upshift to 6th on its own at 72 MPH but my wife usually doesn't go 72 MPH on the 101 freeway where we live in Southern California. Land Rover dealer says its old age and don't worry about it. Any ideas out there?
Old Jun 10, 2019 | 01:38 PM
teklock's Avatar
3rd Gear
I had this happen to me when I had a spare on or a different size tire. I guess the ECU senses the wheels are not going the same speed and won't switch to overdrive.
Old Mar 9, 2021 | 09:10 AM
Mike Atkins's Avatar
good morning. did you ever get this resolved? I have the same issue on a 2006 range rover sport. Thanks.
Old Mar 9, 2021 | 09:11 AM
Did you ever get the shifting problem to 5th and 6th solved? Thanks.
Lord Wert
Apr 12, 2013 10:44 AM
MattyJ2000DiscoII
Apr 6, 2013 10:08 AM
adigerol77
May 13, 2011 02:04 PM
Switzer
Aug 19, 2008 09:02 AM
brooksa
Feb 8, 2008 01:32 PM
