Range Rover Sport L320 (2005-2013) Talk about the Land Rover Range Rover Sport within.
What year do you recommend?
Old Nov 19, 2018 | 10:35 PM
Paulcomi's Avatar
4wd High
Default What year do you recommend?
Been looking seriously at the sport model in years 2008-2013. What’s the consensus about these years in terms of reliability and overall satisfaction? This is a car my family will use around town mostly. I’ll do a fair share of repairs myself with the help of the forum and I don’t want to get into a year known to be plagued by problems and flaws that I could avoid. Appreciate your sage advice as owners.
Old Nov 20, 2018 | 06:51 AM
I assume you mean Range Rover Sport? If so for me I would stick with the 4.4 or 4.2 SC Jaguar motors for the best reliability.
Then maintenance records and a PPI for the win
Old Nov 20, 2018 | 03:33 PM
Paulcomi's Avatar
4wd High
What’s the issue with cars that have a Ford engine? For the money I was thinking of a car between 2010 and 2013 which I believe are all Ford engines correct?
Old Nov 20, 2018 | 07:52 PM
The 5.0 has some well documented costly issues. They are also fragile. One overheat and the engine is generally toast. For example timing issues and High Pressure fuel pumps are two costly common issues.
I think the hyper extended oil change intervals, are partially to blame.
Old Nov 20, 2018 | 08:38 PM
Paulcomi's Avatar
4wd High
Now that’s the kind of information from experience owner that really would save me a lot of heart ache so what year of cars are the best for a RR between say 2005 and 2013? Any car I can afford will likely need to have about 90k mileage.
Old Nov 21, 2018 | 12:47 AM
Paulcomi's Avatar
4wd High
anyone?
Old Nov 21, 2018 | 05:56 AM
06-09 is the 4.4/4.2 Jag motors.
If you can find a 5.0 powered one that has religious maintenance records, and the big ticket items checked off it would still be a fine choice. Just understand that you need to stay on top of the maintenance to. These trucks respond well when maintained. They don't care for neglect.
Old Nov 22, 2018 | 11:21 PM
David_h's Avatar
7th Gear
Well no. The gas 5.0 V8 is a Jaguar engineered engine. I think the diesel v8 was a ford engine.
https://en.wikipedia.org/wiki/Jaguar_AJ-V8_engine#AJ133
Old Nov 24, 2018 | 10:16 PM
Paulcomi's Avatar
4wd High
I’m pretty handy but I have zero experience working on land rovers obviously I get the sense that most of the complaints about reliability have to do with switches and displays as well as the airbag suspension I don’t hear a lot about engine problems am I mistaken?
Old Nov 25, 2018 | 11:02 PM
Kenso's Avatar
The 5.0 engines had timing chain tensioner and guide issues up until '13 or '14 depending on who you ask. If you could find a 2010 or newer model that's already had the updated tensioners and guides installed you would have less to worry about. Also some folks have reported various cooling system failures with overheating while the gauge reported normal temps, causing owners to drive until the point of engine damage because they were unaware of the overheating.
tresean1
Mar 4, 2018 04:44 PM
iconoclast
Discovery Sport
Nov 11, 2017 11:15 AM
Discovery steve
Dec 18, 2014 02:45 PM
XaeroR35
23
Jul 14, 2010 04:22 PM
roberth
Dec 16, 2009 09:16 PM
