Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
2014 Sport Slow coolant leak, Coolant level light on
Old Jun 14, 2022 | 08:31 PM
Eric F's Avatar
Default 2014 Sport Slow coolant leak, Coolant level light on
The radiator hose connector (to the far left of the radiator) on my 2014 Sport popped off while driving and nearly all coolant was gone in minutes. Filled it with water, coolant, bled lines and all good. However low coolant level light goes on every 150-200 miles and I need to fill with about 1/4 to 1/2 cup of coolant. Faint smell after we drive. Coolant system has been pressure checked twice and found nothing. Anyone have any ideas on what to tell my mechanic to check? Thank you in advance....
Old Feb 11, 2023 | 01:23 PM
Ternic05's Avatar
5th Gear
Default Slow coolant leak fix
There is a plastic ‘L’ shaped outlet pipe coming off the water pump. Check to see if your leak isi from there. It’s a very common problem. It will stay in the retainer clip even if the end of it is broken off. A leak will let you know it’s broken. Hope this soles your problem . I replaced mine with a metal pipe
Attached Thumbnails 2014 Sport Slow coolant leak, Coolant level light on-90ded9bb-66cf-4802-bba5-a4efb9591a27.jpeg
RemRyu
Feb 23, 2023 07:43 AM
grapple
LR4
Feb 15, 2020 01:24 AM
oneblessedmess
Feb 16, 2017 03:34 AM
samue23
Mar 1, 2012 05:49 AM
leddifer
Oct 27, 2010 06:33 PM
