Sponsored by: CARiD
OverHeat? no coolant leak?
Old Oct 26, 2010 | 09:36 PM
leddifer's Avatar
Default OverHeat? no coolant leak?
Okay, so i was driving my p38 range rover, it overheated i pulled over imediatly, and my coolant was empty, steam was coming out of the coolant resevoir, and it was wet around it, no hoses apear to be bad... why?! i need help... anyone know whats goin on or how to fix it? i added more coolant but didn't top it off and it started to overheat.
Old Oct 27, 2010 | 06:33 PM
mara9205's Avatar
4wd High
Well seems to me your coolant reservoir hoses are broken,need replaced , also check your head gaskets, thermostat, and make sure you also check for oil leaks and generator. But before anything Do a coolant pressure test and please take it to a certified range rover mechanic. Could be an expensive fixed, Good luck
ZMonet
Jun 24, 2016 04:00 PM
Vantablian
Jul 8, 2013 10:53 AM
alias_J
Jan 31, 2012 11:21 AM
ajs1iron
Mar 8, 2007 12:22 AM
jakea4d2
Oct 26, 2006 11:10 PM
