Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
2019 Sport Rear Axle Problem
Old May 2, 2020 | 08:35 AM
jscott099's Avatar
8th Gear
Exclamation 2019 Sport Rear Axle Problem
Sharing some info about an issue I had on 2019 RR Sport (5L Supercharged) around 14k miles. Each time I wash the vehicle I also clean inside the rims. I started noticing recurring grease splatter on driver side rear. Crawled under and took some pics. Clearly a problem. Dealer replaced the halfshaft under warranty. Unfortunateky, barely a hundred miles later, started noticing a grinding nows (like when a wheel bearing is failing) and occsional brake chirp when backing or turning left. Back to the dealer. This time they replaced wheel bearing and brake rotors (since a gouge had already been cut into one). Not really sure if they goofed doing the first repiar or if it was a secondary problem waiting to happen. A thousdand miles later the dealer rang I wants to take it back in regarding a service bulletin in that same area of the vehicle. Not sure what the bulletin is yet, but just wanted to share this so others can keep an eye out for similar issue.
Old Jul 22, 2021 | 02:31 PM
Mechano2020's Avatar
I am not a RR specialist, but I have seen something similar on a ML 350. It was a punctured boot ... you may want to clean that and see if and where is coming again. Although, you may be running out of grease in that boot.
Nosugar0carbs
Mar 25, 2019 05:29 PM
apollo12
Jan 15, 2019 08:45 PM
shame on U LR
Discovery Sport
Nov 11, 2017 11:11 AM
Northwind
Feb 24, 2016 12:10 PM
pprideaux
Aug 22, 2010 07:13 AM
