Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
No power to start button, no power to dash
Old Feb 22, 2024 | 11:06 AM
llinzi26's Avatar
Default No power to start button, no power to dash
Hi everyone.
i have a 2019 range rover sport. Tried to start it this morning and the dash is completely black, no power or light, and the start button does not work.
car locks and unlocks, alarms work, side steps working normally, lights working fine, boot will not open automatically, but will close when button pressed. Radio and the center screens turn on briefly, but the lights dim after a few minutes. Battery is fine. Called out a mechanic and the diagnostic would not work on the car either. He checked for leaks but everything was dry. He is arranging recovery now so they can get it into a garage to look properly.
anyone else had similar problem? Or does anyone have an idea what could cause this?
thanks in advance
Old Mar 29, 2024 | 03:45 PM
Mumrahdc2's Avatar
Originally Posted by llinzi26
Hi everyone.
thanks in advance
I am having the exact same issue. Were you able to get it resolved??
Old May 13, 2024 | 06:19 AM
The Ger's Avatar
4th Gear
Hi
I've now got the exact same problem. Did you get to the bottom of it the fault. Car currently in the JLR at £220 an hour and they have no idea what is wrong.
Any help would be appreciated?
C
Old May 13, 2024 | 10:00 AM
The Ger's Avatar
4th Gear
Did you have any joy in finding what your issue was ?
Thanks
Old Aug 17, 2024 | 01:07 AM
Lin113's Avatar
Good morning,
Have you by any chance found a solution to this problem? I have a car here with the same problem and look forward to your response
Old Aug 17, 2024 | 01:11 AM
llinzi26's Avatar
Hi guys, it was the BCM that caused my problems. The part was on back order with no available date at the time. It took a good few months to get the part. Had no problems since it was fixed!
Old Jan 5, 2025 | 11:09 AM
stevenscott@hotmail.co.uk's Avatar
Originally Posted by Lin113
Good morning,
Hi, have you also replaced the BCM and has this resolved the problem?
Cordovaii@me.com
Range Rover L405 (Fourth Gen)
Dec 2, 2023 05:35 AM
chris-ireland
May 22, 2023 05:03 PM
roveruser2013
Dec 1, 2019 04:38 PM
Kazbat
Dec 13, 2017 03:43 AM
westminster04
May 13, 2009 09:55 PM
