Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Power seat failure
Old Apr 22, 2020 | 09:45 AM
Poohgas's Avatar
Default Power seat failure
Good morning. I was pressing the drivers side lumbar button on my 2014 rrs hse (vehicle engine not powered on at time), when all of a sudden it stopped working. Now none of the seat buttons on either drivers or pass side work. Memory buttons do not work either. All other vehicle features still work such as tilt steering, windows, wipers, mirrors etc. Issues seem limited just to the seats. I have checked 3 fuses behind glove box, and all 3 were good. At a loss as to what to check next?
Old Jan 16, 2021 | 04:58 PM
offlandy42's Avatar
4th Gear
Default Same issue!
Hey poohgas, Happy New Year!
So what was the solution to this problem?!
Hope your problem is solved!
I have the exact same issue. my car is a 2014 L494. Seat were working fine, and then all of a sudden broke down when adjusting. All 3 Fuses are intact even on my car. One of my headrest is stuck at the top most position, wonder if that is causing some issue..?
Regards,
Old Jan 16, 2021 | 05:12 PM
Poohgas's Avatar
I replaced 1 fuse I found had burnt out. Was located in rear cargo area fuse panel. Worked for about 5 seconds then burned out once again. I let it go for about 3 months. Once again went to same fuse panel and realized there were 2 fuses located there related to power drivers side seat, and replaced them both. Seat has been working fine ever since. Now I’m having an issue with the drivers side rear brake light lol
Old Jan 16, 2021 | 05:45 PM
offlandy42's Avatar
4th Gear
Default Thanks
Awesome! Will try out soon. Hope you find a fix for the rear light !
Greetings
erick846
Oct 1, 2015 10:23 AM
Just For Fun
Aug 16, 2013 09:27 AM
Mrcreeper3435
Feb 20, 2013 09:33 PM
fitch11
Oct 18, 2007 02:58 PM
wbdaily
Jul 9, 2007 07:20 PM
