Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Public service announcement- all 5.0 & 3.0 owners
Old 07-13-2019, 11:28 AM
abran's Avatar
Default Public service announcement- all 5.0 & 3.0 owners
The 5.0 GDI and the 3.0 GDI motors have been having issues with carbon deposits on the valves.
This is an inherent design flaw in the GDI motors. Since the fuel injectors are directly positioned in the combustion chamber, fuel never passes the valves, thus never cleaning them. With engineers working to increase motor efficiency, they have reduced the piston ring tension rates. deposits form on the rings leaving gaps in the ring seal allowing fuel and air to get in the oil and for oil to get into the combustion chamber. Once oil gets into the combustion chamber it looks for the coolest place to rest, back of the valves.
These motors have been dropping valve seats and causing owners to have to replace or machine heads, not cheap.
We have been doing the BG petrospecs EPR engine service at our shop. While this will not remove the carbon on your valves, it will emulsify the carbon deposits on your rings creating a uniform seal on the cylinder walls, restoring compression.
Here is a link to the BG explanation:
https://www.bgprod.com/blog/under-pr...-piston-rings/
User (11-12-2019)
Old 07-23-2019, 11:56 AM
Brandon318's Avatar
Hmm, interesting. Any advice for how to remove carbon buildup on the back of valves? Or by doing this, will it reduce oil blow-by, thereby reducing additional carbon buildup?
Old 07-25-2019, 12:24 PM
abran's Avatar
Just spoke with the BG rep yesterday. They have created a new product to help get rid of the gunk.
Old 07-26-2019, 11:35 AM
Brandon318's Avatar
How did he recommend applying the product? That's the real issue. I was looking at the factory service manual and it looks like not the worst job in the world to remove the "lid" of supercharger to expose the intake valves and manually clean. Not sure yet.
Old 11-12-2019, 01:29 PM
User's Avatar
I walnut blasted my MINI Cooper. I think it would be worth it to keep using these BG products as well as remove the intake eventually to walnut blast the valves. Just have to verify they're closed and start blasting. Messy but easy.
abran
07-13-2019 11:26 AM
abran
LR4
07-13-2019 11:24 AM
abran
07-13-2019 11:21 AM
josher-mi
05-15-2019 08:56 AM
User
05-10-2019 01:10 PM
Quick Reply: Public service announcement- all 5.0 & 3.0 owners
