Range Rover Sport L494 (2013-present) Talk about the Land Rover Range Rover Sport within.
Suspension fault
Old Apr 7, 2024 | 02:10 PM
Bgulsvig's Avatar
Default Suspension fault
I recently purchased a 2014 RR sport. There was a leak in the air suspension and the dealer had it repaired by a non-land rover mechanic. Does the system need to be reset or recalibrated? It adjusts to the three ride heights correctly but shortly after driving off the “suspension fault” warning appears and the terrain response features are disabled.
Old Apr 10, 2024 | 08:04 AM
Hugh166's Avatar
I'm assuming you bought it from a non Land Rover dealer? If it is a Land Rover dealer call them right back. You're going to have to get some codes pulled to see what is going on. To test for a leak you can get the truck to sit at normal height and disconnect the battery overnight. Then in the morning you will see which corner is down. But if you disconnect the battery you may wipe out the codes stored so I would suggest scanning it and getting those first.
erneubauer1972
Oct 22, 2022 11:17 PM
OramaSEPR
Nov 8, 2021 02:19 PM
PeterOZ
Feb 3, 2013 08:04 PM
