LR3 Suspension Fault Message
Old Jul 30, 2022 | 12:36 PM
erneubauer1972's Avatar
7th Gear
Default LR3 Suspension Fault Message
I have an '05 and am getting a suspension fault error but the suspension is raising and lowering just fine. Is this a sensor issue.
I have a 2" Johnson Rod Lift
Old Jul 30, 2022 | 01:18 PM
DakotaTravler's Avatar
What are the codes?
Old Jul 30, 2022 | 01:28 PM
7th Gear
What are the codes?
It says "Suspension Fault" Dont Drive more than 30 mph
Has the yellow/red truck flashing on the left bottom of my Guages.
Again, the car is riding fine. This is why I am wondering about sensors. Had the right, front air suspension replaced not too long ago.
Old Jul 31, 2022 | 01:38 PM
Rufflyer's Avatar
Default You need to know why the light came on.
What are the codes?
Originally Posted by erneubauer1972
............Has the yellow/red truck flashing on the left bottom of my Guages..............
As a general rule, these lights won't come on unless there is a DTC code. If you have a diagnostic tool that can read Land Rover codes, read all codes that it can find not just the latest ones. If you do not have a diagnostic tool, you are at the mercy of a repair shop or the dealership.
Jeff
Old Jul 31, 2022 | 01:57 PM
7th Gear
What tool do you recommend I purchase.
Old Jul 31, 2022 | 02:33 PM
houm_wa's Avatar
Default IIDTool by GAP Diagnostics...
...was the suspension recalibrated after the new sensors were installed? Going from yellow to red (at speed) suggests bad desiccant/air drier/solenoid valve to me...need the codes though. It would help to know which compressor you have, too. Hitachi v AMK.
Old Oct 19, 2022 | 10:08 AM
7th Gear
Thank you for your help. I am going to get the information and get back to you. I really appreciate the assistance.
Old Oct 22, 2022 | 11:17 PM
Coldwater's Avatar
Hello,
curious if any one can help me with the same problem. The Rear Diff had a wire that was chewed by a rodent. Causing a transmission fault to show up. This got fixed a few months ago. NOTE: I have the locking rear diff. Now just recently I’ve had these lights show up randomly. They disappear after shutting off and restarting the vehicle.
According to my Gap Tool. The rear diff, transmission and transfer case need an update. Think this would be the solution?
These are the codes I’ve seen come up after the three lights come on. Instrument Pack
  • U0132-87 (2E) Lost communication with ride level control module - Bus signal/message failure - missing a message
Rear Diff
  • P186D-00 (28) Clutch actuator stuck
    ( on 18-06-2022 22:53:12 at 9975982mi )
Vehicle Dynamic
  • U1A4A-68 (08) Invalid data received from differential control module - rear - Algorithm based failure - event information
    ( on 21-10-2022 13:07:23 at 162085 mi )
Nicepackage
May 29, 2019 10:30 AM
PeterOZ
Feb 3, 2013 08:04 PM
chris_craft
Jul 30, 2008 09:07 PM
