Range Rover Velar Talk about the Land Rover Range Rover Velar within.
2018 Velar DRL not working
Old Sep 28, 2024 | 08:58 AM
Fantom's Avatar
Default 2018 Velar DRL not working
My DRL on the left side are not working. I know the entire LED light assembly cost around $900 ($450 refurb) and I don't have that find of money. Can anyone point me in the right direction as to what could be the problem? is it the chip modules that need replacing, the small motor, etc? Can I pull a code and see exactly what the issue could be? I've attached a photo of my right and light side. Keep in mind the left light is entirely on even though it may not show it in the photo.
Thanks in advance
working
not working
Old Jan 5, 2025 | 08:46 AM
stanislandy's Avatar
5th Gear
Default Same problem
Hello Fantom,
Did you ever get any replies for this post? Were you able to resolve without purchasing a new light?
I have the same problem on the same side. Saw where you can order the modules and I did. Had seen where the lens can be removed using an oven and some simple tools but light is too large for most ovens. Then it appears that removing via heatgun is also a possibility although in the videos I’ve seen the lenses are broken.
Would like to know how you repaired yours if indeed you have.
Thanks in advance for your reply!
Low Country
Jun 21, 2024 03:58 PM
Greggo171117
Range Rover L405 (Fourth Gen)
Jun 6, 2023 02:49 PM
Enygma
Range Rover Velar
Feb 23, 2023 11:17 AM
Arrowe
Feb 29, 2020 08:50 PM
Flybye
Discovery Sport
Jan 10, 2019 07:04 PM
