ROAMING WITH FRIENDS Make friends, socialize, share pics and other non technical threads.
speed channel
Old Dec 27, 2010 | 07:45 AM
ngarover's Avatar
Originally Posted by tweakrover
My guess is he was a good friend of the shop guys, that they knew was a competent offroader. he found out they were doing a show and wanted in. you don't do a trip like that in those conditions, without knowing your group is all capable. Out there things can go south quick.
I totally agree. in the video, he said he had been on these trails over a dozen times. He was acting as the guide, reading the map etc. I wonder if those dozen of so times where all in his rover?
Old Dec 27, 2010 | 10:40 AM
kevlor80's Avatar
Hey Jull....I caught the show on Speed here in B.C. just last week and then here in Alberta thru Xmas. I thought it was great for I just picked up my 95 white Disco about 4 weeks ago from a friend......timing is everything!
Old Dec 27, 2010 | 10:43 AM
kevlor80's Avatar
DiscoJag.....had to reply after noticing the 01 VDP in your signature......great taste!
Old Dec 27, 2010 | 01:13 PM
Jull's Avatar
I don't have speed channel at home and I wanted to watch it on the net. I've been searching for 2 hours for a working video and didn't find any.
Old Dec 27, 2010 | 03:30 PM
ColoDisco's Avatar
As far as I can tell it only needed help twice.
Really does not benefit the jeeps as it shows the Rover is pretty capable with minor modification.
Old Dec 27, 2010 | 03:44 PM
Garrett's Avatar
The Hulu link didn't work, jsut loaded a GM advert
Old Dec 27, 2010 | 09:59 PM
demonlarry's Avatar
just watched it. good documentary, loved the fact the Disco did so well.
Old Dec 28, 2010 | 10:06 AM
Dezert Rover's Avatar
I've read a few times now where people mention "fixing the dash curl".... what the hell is dash curl?
Old Dec 28, 2010 | 10:57 AM
tweakrover's Avatar
The dash cover curls back up by the defroster vents
Old Dec 28, 2010 | 03:07 PM
ngarover's Avatar
The dash curl is the curling of the dash from being in the sun. It was a really poor design and landrover has a fix for it, which is basically a couple molded plastic strips that you screw down and hold the dash pad in place. can be a pain in the butt job with the windshield in to fix (I've done it to my 96) But with the windshield out it would be about a 10 minute job. Looks factory when your done. You can get the strips for about 20 bucks. The other option is to remove the windshield, use an industrial glue and clamp the pad down until the glue holds. I have not done this, but have seen shops that do it.
grandkodiak
Mar 11, 2011 01:31 PM
Antmen
Off Topic
May 18, 2010 05:10 AM
dmonares
Feb 1, 2010 06:53 AM
henrythomas
Audio/Visual Electronics
Nov 4, 2009 09:35 PM
Spike555
16
Aug 26, 2009 06:57 PM
