speed channel
My guess is he was a good friend of the shop guys, that they knew was a competent offroader. he found out they were doing a show and wanted in. you don't do a trip like that in those conditions, without knowing your group is all capable. Out there things can go south quick.
Hey Jull....I caught the show on Speed here in B.C. just last week and then here in Alberta thru Xmas. I thought it was great for I just picked up my 95 white Disco about 4 weeks ago from a friend......timing is everything!
The dash curl is the curling of the dash from being in the sun. It was a really poor design and landrover has a fix for it, which is basically a couple molded plastic strips that you screw down and hold the dash pad in place. can be a pain in the butt job with the windshield in to fix (I've done it to my 96) But with the windshield out it would be about a 10 minute job. Looks factory when your done. You can get the strips for about 20 bucks. The other option is to remove the windshield, use an industrial glue and clamp the pad down until the glue holds. I have not done this, but have seen shops that do it.
