1978 Santana 109 Disc brake conversion help
Greetings, I am finally getting around to improving the drivability of my Santana and would like to put a set of disc brakes on the front. I welcome any opinions from members here. I am running a 200tdi engine Lt77 combo and the drums were never sufficient and are now useless. I have 17" defender wheels so clearance should not be a huge issue. I like the look, cost, and simplicity of the Zeus Z1301 kit (Land Rover :: ZEUS FRONT DISC BRAKE CONVERSION KIT, Land Rover SERIES II & III - Low Stock -) but i can't get in touch with anyone at their contact info so i don't know if they are still in business. Other options i have found are much more expensive, but i believe this is becasue they account for clearance issues I won't encounter.
Thanks for your time
Check out: TeriAnn's Expedition Land Rover site
TeriAnn has a ton of great info on there. Some is brake related.
Forbyn Brothers sell a kit too. Forbyn Bros. | Quality parts for your classic Land Rover
I'm in the process of a V8 conversion on my Santana Series IIa. While looking at the disc conversions, I came to the conclusion that it would be less expensive to just buy a set of used Disco 1 axles with the brakes already installed. I'm also going to convert it to a coiler while everything is off the chassis.
I have what I think is a 1983 Santana 2500. The fellow I bought it off of has a title with 1974 model year. I don't think that's correct. Anyway, I'm about to jump into the brakes. The fronts are disc and I'm looking for replacement parts. I can't tell if my disc brakes are OEM (Santana) or a conversion before it was imported into the US. I'm wondering if you've had any luck with yours.
BTW, I live in NC.
Thanks!
Mike
BTW, I live in NC.
Thanks!
Mike
TRIARII
Nov 13, 2014 01:30 PM
dinandan
Jan 11, 2007 12:55 AM
