Series I, II, IIa, III Land Rovers For all Series Land Rovers
1978 Santana 109 Disc brake conversion help
Old Mar 1, 2021 | 10:00 PM
Wrickm79's Avatar
Default 1978 Santana 109 Disc brake conversion help
Greetings, I am finally getting around to improving the drivability of my Santana and would like to put a set of disc brakes on the front. I welcome any opinions from members here. I am running a 200tdi engine Lt77 combo and the drums were never sufficient and are now useless. I have 17" defender wheels so clearance should not be a huge issue. I like the look, cost, and simplicity of the Zeus Z1301 kit (Land Rover :: ZEUS FRONT DISC BRAKE CONVERSION KIT, Land Rover SERIES II & III - Low Stock -) but i can't get in touch with anyone at their contact info so i don't know if they are still in business. Other options i have found are much more expensive, but i believe this is becasue they account for clearance issues I won't encounter.
Thanks for your time
Old Mar 3, 2021 | 10:02 PM
Harvlr's Avatar
Have fun with the conversion. The drum brakes on my 88 are quite adequate (except after driving through water) so I’ve never felt the need to upgrade.
Old Jan 11, 2023 | 02:43 PM
capejohny's Avatar
I am wrestling with a 1984 Santana. I can't track down the rotors for this.. Is there a replacement rotor I can buy instead of the original 173222 models?
Old Feb 21, 2023 | 08:15 AM
sean2a's Avatar
were you successful in the conversion?
don
Old Feb 23, 2023 | 01:14 PM
Moofer's Avatar
7th Gear
Check out: TeriAnn's Expedition Land Rover site
TeriAnn has a ton of great info on there. Some is brake related.
Forbyn Brothers sell a kit too. Forbyn Bros. | Quality parts for your classic Land Rover
Old Mar 7, 2023 | 03:01 PM
Hooligan's Avatar
Default Disc brakes
I'm in the process of a V8 conversion on my Santana Series IIa. While looking at the disc conversions, I came to the conclusion that it would be less expensive to just buy a set of used Disco 1 axles with the brakes already installed. I'm also going to convert it to a coiler while everything is off the chassis.
Old Mar 7, 2023 | 05:07 PM
Harvlr's Avatar
That’s probably a really good idea with your V8. The Disco axles and diffs are way tougher.
Old Oct 30, 2025 | 01:54 PM
AluminiumMikw's Avatar
I have what I think is a 1983 Santana 2500. The fellow I bought it off of has a title with 1974 model year. I don't think that's correct. Anyway, I'm about to jump into the brakes. The fronts are disc and I'm looking for replacement parts. I can't tell if my disc brakes are OEM (Santana) or a conversion before it was imported into the US. I'm wondering if you've had any luck with yours.
BTW, I live in NC.
Thanks!
Mike
Raider TD5
Defender
Jun 12, 2014 06:01 AM
nickwood
Defender
Mar 31, 2012 07:47 AM
landyjd
Defender
Feb 11, 2011 08:15 PM
dinandan
Jan 11, 2007 12:55 AM
