My Series III does not have the rear grab handles (I've also seen them called lift handles), and does not have holes drilled in the rear crossmember for them either. Can someone who has these pieces measure the bolt locations? I really only need the location of one bolt because all the rest naturally fall in place after that. Maybe measure down from top of crossmember to center of bolt, then from outer edge of crossmember to center of same bolt.
Also, should I use black or natural handles? Crossmember is black and all the galvanized parts on the truck are still original galvanized finish.
