Series I, II, IIa, III Land Rovers For all Series Land Rovers
Rear Grab/Lift Handle Position?
Old Aug 27, 2021 | 07:33 PM
XXL's Avatar
XXL
Default Rear Grab/Lift Handle Position?
My Series III does not have the rear grab handles (I've also seen them called lift handles), and does not have holes drilled in the rear crossmember for them either. Can someone who has these pieces measure the bolt locations? I really only need the location of one bolt because all the rest naturally fall in place after that. Maybe measure down from top of crossmember to center of bolt, then from outer edge of crossmember to center of same bolt.
Also, should I use black or natural handles? Crossmember is black and all the galvanized parts on the truck are still original galvanized finish.
Thanks in advance for your help.
Old Sep 2, 2021 | 04:37 PM
tluchette's Avatar
Default Grab bar location
Here’s pics of me measuring with the bar installed.I just put mine on so I don’t want to remove them 😜 but should give you an idea.
wonder why you don’t have the holes pre-drilled.
Old Sep 2, 2021 | 09:03 PM
XXL's Avatar
XXL
Thanks! That's just what I needed. I don't know why there are no holes. Maybe the hole driller at the factory was sick that day
ahab
Jun 19, 2021 02:17 PM
Maxelam0822
LR4
Sep 24, 2020 02:27 AM
TennRover
Sep 11, 2019 08:09 AM
DR.DREW2
Dec 21, 2016 01:02 PM
cybercop
Aug 31, 2015 04:08 PM
