Series I, II, IIa, III Land Rovers For all Series Land Rovers
Rear wheel doesn't seem to line up with wheel well
Old May 30, 2024 | 02:49 PM
WaltNYC's Avatar
Default Rear wheel doesn't seem to line up with wheel well
Hello,
I usually inhabit the D1 section and am looking to gain more knowledge about the Series vehicles.
In this BaT listing https://bringatrailer.com/listing/19...iia-santana-5/
it seems to me that the rear wheels are not properly aligned in the wheel well. I believe I've noticed this before on Series trucks. Is there something to this or am I just looking at it all wrong?
Old May 31, 2024 | 12:25 PM
XXL's Avatar
XXL
Strangely enough, that is normal.
Old May 31, 2024 | 01:35 PM
Harvlr's Avatar
If you mean fore and aft, the leaf springs have a fixed pivot point at the front of the springs, so the wheel will move fore and aft as it moves up and down with different loading.
Old May 31, 2024 | 02:24 PM
WaltNYC's Avatar
Got it. So when that side of the suspension is compressed, the leaf spring acts as an arm moving through an arc. By the time it hits fully horizontal, the wheel is centered (or even aft).
Thank you for that explanation.
Old May 31, 2024 | 07:22 PM
Harvlr's Avatar
I wish I could find a better photo of mine, but here it is. I don’t regret selling it, but I do miss it.
Old May 31, 2024 | 08:02 PM
XXL's Avatar
XXL
I wouldn't describe it quite like that, but it is close enough conceptually. Leaf springs have an arch to them. As when anything curves gets straightened, it gets longer. For leaf springs, there is a dead head and a live head (some have toyed with live heads at both ends over the centuries, including on transverse setups, but found it more complicated and rarely more effective, but it's not possible to actually pull off dead heads at both ends becauae of the physics of it all-- the spring has to get longer... but it can't). With one end fixed (the dead head), the other end (live head) relies on a shackle or other 'slider' mechanism to move when the spring is forced into compression. This dead-live configuration means the axle necessarily moves rearward during compression because the spring is longer.
In the case of LR, they decided (or tossed a coin?) that the "wheel centered in opening" position would be under so.e quantity of spring compression, whereas 99.99% of other manufacturers locate the center with the spring at rest... likely because people notice such things looking at their car in the driveway, but not in the instant that the suspension is compressing under load from a hooptie in the trail.
/2 cents
Old Jul 5, 2024 | 09:42 PM
Larmo63's Avatar
3rd Gear
Like this?
Elzot
May 5, 2024 02:29 PM
taylorswiftgang
Oct 19, 2023 08:18 AM
Steve59
Range Rover L322 (3rd Gen)
Jun 4, 2023 11:26 AM
Springlandy
Defender
Jan 16, 2022 04:29 PM
nickm347
Jan 15, 2017 05:10 PM
