Series I, II, IIa, III Land Rovers For all Series Land Rovers
Overheating issues
Old Jul 5, 2024 | 09:23 PM
Larmo63's Avatar
3rd Gear
Default Overheating issues
My ‘59 Series II 88 has no fan on the water pump but a pusher fan. This set up isn’t optimal, and now the switched fan has stopped working. NOT GOOD.
Dumb questions:
Where is the fuse box on a Series II?
Could it be that the dash switch has gone bad?
I believe this truck has a Series III engine in it.
Do I add a fan to the existing water pump, new radiator?
there is no fan shroud.
Temps are going/showing past 190 degrees.
Help?
Old Jul 7, 2024 | 05:54 PM
Harvlr's Avatar
My ‘63 2A had the fan on the water pump. I don’t think your setup is normal. The fuse panel (on mine) was in the engine compartment, on the RH side of the firewall. Only 2 fuses for the whole vehicle.
Old Jul 7, 2024 | 07:49 PM
I would go on the roversnorth website and get yourself a proper cooling system. Order the fan shroud etc and put it back to stock
BraziliaNut
Oct 2, 2023 08:45 PM
rlcj_racing
Jan 5, 2017 11:52 AM
bbaileyii
Sep 27, 2013 09:08 AM
jaydog101
Jan 15, 2012 11:00 PM
freeranger
Mar 29, 2005 06:03 PM
