Series I, II, IIa, III Land Rovers For all Series Land Rovers
S2A Leaking diff cover
Old Apr 10, 2022 | 03:59 PM
EricG.'s Avatar
3rd Gear
Default S2A Leaking diff cover
My '70 S2A has a leaky rear diff cover. My mechanic says he can grind off the rust and fill cover the diff cover with JB Weld epoxy. I have had good luck with the stuff but I'd like to hear what fellow Series Rover owners think. ????
Old Apr 11, 2022 | 01:21 PM
XXL's Avatar
XXL
Is your mechanic suggesting there is rust on the mating surfaces of the cover and the diff housing itself? That's a very odd place for rust to form unless the unit was left disassembled for years. If indeed the mating surfaces have pitted due to rust, I have no issue with using JB Weld as a skim coat to fill the pits, then file it back down smooth before using a regular gasket and gasket sealer. I've done this on a water neck that had pitted mating surfaces. The way you've written your post however, I have this sinking feeling that you or your mechanic is considering JB Weld to glue the cover in place... if that's what's being suggested, you need to get another mechanic... FAST!
Old Dec 13, 2024 | 05:03 AM
irontmp's Avatar
Banned
Originally Posted by XXL
Is your mechanic suggesting there is rust on the mating surfaces of the cover and the diff housing itself? That's a very odd place for rust to form unless the unit was left disassembled for years. If indeed the mating surfaces have pitted due to rust, I have no issue with using JB Weld as a skim coat to fill the pits, then file it back down smooth before using a 14 bolt differential cover for regular gasket and gasket sealer. I've done this on a water neck that had pitted mating surfaces. The way you've written your post however, I have this sinking feeling that you or your mechanic is considering JB Weld to glue the cover in place... if that's what's being suggested, you need to get another mechanic... FAST!
Drivers side diff cover is leaking. This is a M6. Can I drain, pull axle and remove cover without droping the carriage and disconecting the trans ? Looks like it is possible except for one trans bolt thru the cover. Will I be able to pry the cover away from the rear and then slide in back ? And then reverse the process with gasket sealer or new gasket ?
Old Dec 13, 2024 | 05:32 PM
Harvlr's Avatar
What kind of car are you talking about? I think you’re in the wrong forum
Snas2013
Freelander
Jun 5, 2019 12:26 PM
bosshogt
Aug 1, 2011 09:35 PM
Bundu
Apr 8, 2011 01:49 PM
Sbonomo
Apr 15, 2009 09:54 PM
bigugly82
Aug 3, 2007 06:28 PM
