Series I, II, IIa, III Land Rovers For all Series Land Rovers
series iii no power to rear wheels
Old Nov 29, 2022 | 04:34 PM
Nbblake's Avatar
5th Gear
Default series iii no power to rear wheels
I just acquired this 1982 Series iii lightweight. All was going well until I left an intersection in first gear, hear a sound from below (like a piece of metal broke or dropped out) and then the engine just revved as if in neutral. I can shift it into all gears but the gears won't engage, in other words there is no drive to the rear wheels. If I put it into 4wd then I can drive it with front wheel drive only but still nothing to the back. Anybody have any ideas what happened before I start taking things apart?
Old Nov 29, 2022 | 05:14 PM
Harvlr's Avatar
Most likely a broken axle. They are cheap. They break routinely. If it broke at the wheel end it’s a very easy change. But they usually break at the diff end. Still not difficult but you need to remove the 3rd member (doughnut) to get the broken piece out.
wncrrcSIIA
Nov 29, 2022 04:24 PM
MCKEAG
Feb 26, 2014 07:27 AM
bobalou
Oct 21, 2013 04:27 AM
novatim
Nov 20, 2006 11:42 AM
McDougal
May 5, 2006 06:04 PM
