Series I, II, IIa, III Land Rovers For all Series Land Rovers
Starting problems
Old Dec 12, 2021 | 08:38 AM
Outmans's Avatar
4th Gear
Default Starting problems
I have a problem with my Landrover Range rover 2.5dse p38, bmw engine. He won't start. If I put brake cleaner in the air supply, it starts immediately and runs fine. If I then turn it off and start it within 20 seconds, there is no problem. If I wait longer, it won't start again. It also has this problem when it is warm. There is pressure at the feed pump at start up so this is not the problem. At the injectors there is little/no pressure at start. Hope someone has this problem before and know how to fix it.
with kind regards
Old Dec 12, 2021 | 10:36 PM
Harvlr's Avatar
This is definitely not the right area of this forum for your post. This area is for “Series” Land Rovers. The actual right area to post this would be in the Range Rover P38 section, but as it is probably an engine issue (and not a body issue) you should be able to post this in the Discovery 1 or 2 section to get more views and replies. I would suggest Discovery 1 if yours is pre ‘99 or Disco 2 if ‘99 or newer.
Old Dec 13, 2021 | 02:01 AM
Outmans's Avatar
4th Gear
thank you
westmirover
Dec 13, 2021 05:46 AM
BOSOX
Freelander
Jul 9, 2011 11:45 AM
St3fanPL
Freelander
Mar 18, 2011 02:23 PM
TheSaint
Feb 6, 2011 04:00 PM
jrover66
Nov 15, 2008 03:30 PM
