Will 4.6 bolt into 4.0?
Old Aug 5, 2016 | 08:02 AM
clint70's Avatar
Default Will 4.6 bolt into 4.0?
So, I have had some issues with the engine... it is getting close to the time to either rebuild or replace the engine I have found a 2003 4.6 that someone is willing to sell for 350.00 it is complete with all the auxiliary parts. The heads need to be done (not an issue for me). But I am wondering IF the 4.6 will bolt right into place? Appreciate any help / advice.
Cheers!
Old Aug 5, 2016 | 08:22 AM
Fast951's Avatar
Yes it will bolt right in. Does your '02 have SAI (Secondary Air Injection)? If so and the $350 4.6 does not you'll need to swap your 4.0 SAI heads over so all of the plumbing works properly and you don't get error codes.
Old Aug 7, 2016 | 03:11 PM
clint70's Avatar
You are right... it is an SAI, but I do have a set of 4.0 non-SAI heads. Question is will these heads work on the 4.6 engine?
Old Aug 7, 2016 | 08:34 PM
Charlie_V's Avatar
The heads are interchangeable. I've done it.
Old Aug 9, 2016 | 09:31 AM
Fast951's Avatar
Yes, confirming the heads are interchangeable. Only thing to be aware of is using SAI heads on a non-SAI vehicle you have to thread plugs into the SAI ports on each head.
That looks like a clean engine for $350; hope the internals are good. The oil filter is an OEM LR unit which may be a sign of proper maintenance by the PO. Good luck with the swap.
Old Aug 9, 2016 | 10:23 AM
Charlie_V's Avatar
Just to add... when I swapped sai heads into a non SAI truck I just filled the fittings with weld material. They still interfere with the head bolts. Then I found that my non SAI heads had small threaded plugs in them. If your do, too, that's the preferable route.
Also, the stock 2003 sai heads that I swapped on were very soft. The threads stripped in several places at recommended torque and I had to helicoil them. That was probably specific to those heads.
focusontheworld
Oct 21, 2012 01:00 AM
03discoman
Feb 19, 2010 03:05 PM
GJgo
Jun 26, 2009 08:54 PM
kumbhani123
Oct 10, 2005 11:08 PM
sclarkie
Aug 9, 2005 04:01 PM
