Florida Rover's 1997 Discovery XD
Old Jan 24, 2017 | 03:15 PM
FloridaRover's Avatar
Default Florida Rover's 1997 Discovery XD (PIC HEAVY)
Welcome to Florida Rover's 1997 Discovery XD Build Thread.
This is a build, maintenance, and wheeling thread since acquiring the vehicle on November 30th, 2016.
The truck was posted for sale by another member, on the forum and Orlando Craigslist, I had contacted him about a month prior to purchasing to test the waters;
https://landroverforums.com/forum/pr...very-xd-81511/
After test driving one evening around Downtown Orlando, I walked due to the truck's temperature and price being far too high.
In addition, it had also been flopped* onto the passenger side and the transfer case shifter was stuck.
3 days later I purchased the truck for $3000..
Basic Information:
1997 Land Rover Discovery XD, Purchased at 185,193 miles
4.0L GEMS V8
ZF 4HP22 Transmission
LT230 Transfer Case
AA Yellow
Safety Devices Roof Rack
XD Sticker Package, Wheels, Ladder, & Light guards
General List of Modifications:
This list of modifications includes many replaced or maintenance items, as this is documentation of a build / restoration.
ENGINE, AIR/FUEL, FORCED INDUCTION
Champion spark plugs and wires
Aluminum radiator
Genuine Mantec snorkel
ENGINE DIAGNOSTICS
Scangauge E
FLUIDS & FILTERS
Rotella 15w-40
K&N 3001 oil filter
K&N air filter
Peak green coolant
O'Reillys high mileage ATF
O'Reillys 85-140w gear oil
EXHAUST
Flow master high flow cats & cherry bomb muffler
DRIVETRAIN
Factory 3rd member U joint
Transfer case solenoid removed
Front CV axles & drive flanges replaced
BRAKES/HUBS
Terrafirma extended stainless steel brake lines
Rear brake pads replaced
Front brake pads replaced
Swivel ***** rebuilt with Britpart kit
Front wheel bearings replaced (Timken)
Rear wheel bearings replaced (Timken)
SUSPENSION
Sway bars removed
Terrafirma medium duty suspension lift
Terrafirma rear dislocation cones
Terrafirma steering damper
WHEEL/TIRE
(2) Sets XD style wheels
Terrafirma 30mm wheel spacers
Irok ND Super Swampers 285/75/16
EXTERIOR ARMOR, STYLING & REPLACEMENTS
Saudi style grille
Black Land Rover emblems
Tactical Rovers front bumper w/ steering skid
Tactical Rovers rear bumper
Integrated factory tow hitch
Rocky Road Super Sliders
Terrafirma differential guards
Genuine taillight guards
Fenders & quarter panels trimmed to accommodate tires
EXTERIOR PAINT WORK
Rustoleoum Semi Gloss Black
Saudi grille
Steering skid
Muffler tip
Swivel housings
Brake mud / dust shields
Inner fenders & wheel wells
Rocker panels & sliders
Rear wheel wells
Driver A pillar
Air filter housing
Snorkel
EXTERIOR LIGHTING
Sylvania Headlights
9" LED front fog lights
4" LED reverse light
Front fogs relocated to winch lights
Rear fogs relocated to rock lights
INTERIOR STYLING/REPLACEMENTS
Discovery 2 door seals
Lights converted back to halogen bulbs
Homelink installed
Genuine black rubber floor mats
Sun visors & overhead map storage from donor
Passenger seat from donor
Center console from donor
Lights & turn signal stalk from donor
Rear window ECU repair
Rear window roller repair
Passenger side mirror from donor
Genuine CDL sticker replaced
INTERIOR PAINT WORK
Floor pan rust treated & sealed with Miracle Paint
3rd brake light cover painted SEM trim black
ELECTRICAL
AGM deep cell battery
Mean Green high output alternator
SOUND SYSTEM & COMMUNICATION
Pioneer Bluetooth headunit
Cobra CB Radio & 3' Firestik II antenna
OFF ROAD ACCESSORIES & SAFETY EQUIPMENT
Viar on board air system
Badlands 12,000 lb. winch
5.75t yellow D ring shackles
Smittybilt rear hitch recovery point
Hi Lift Extreme Jack & roof rack mount
5 lb. Axe & Shovel
(2) 15 lb. fire extinguishers
Old Jan 24, 2017 | 03:19 PM
I believe the truck started it's life in Florida after finding a single stamp from Land Rover West Palm Beach in the "Passport to Service" manual.
The earliest service records I have available place the truck in Louisiana in May 2002.
Owner: Mary Furman
Date: May 31st, 2002
Mileage: 84,025
Problem: CEL on, look over car for long road trip
Service: 82,500 mile service, front brake pads, serpentine belt, valve cover gaskets
Date: May 22nd, 2003
Mileage: 93,475
Problem: Overheating at idle
Service: Replaced radiator and thermostat, oil and filter,
Date: August 18th, 2003
Mileage: 98,420
Problem: PS leaking fluid, Overheating at idle
Service: Replaced steering box and hoses, replaced condenser fans
Date: April 8th, 2004
Mileage: 112,794
Service: Oil and filter
Date: July 23rd, 2004
Mileage: 114,567
Problem: Not starting, belt is loose, overheating, exhaust leak, CEL, key wont turn corectly
Service: New battery, serpentine belt, water pump, thermostat, hoses, spark plug & wires, fuel injector, transmission fluid, exhaust manifold gaskets
Date: November 9th, 2005
Mileage: 115,589
Problem: Vibration at 50 MPH, ABS light, check brakes, overheating while going uphill
Service: Front steering damper, bushings, rotate and balance tires, brake pads, coolant flush
Date: February 7th, 2008
Mileage: 118,907
Owner: Aaron Johnson
Date: June 4th, 2008
Mileage: 130,000
Problem: Head Gaskets
Service: Check radiator, bled brakes, remove oil pan & clean pickup, R&R heads, reconditioned heads machined, head surface and valve seals, new head bolts, thermostat, spark plugs, wires, filter, fuel filter, serpentine belt, oil and filter.
Date: February 2nd, 2009
Mileage: 125,004
Service: Replace left front brake caliper, bled brakes
Date: June 11th, 2012
Mileage: 166,549
Location: Jackson's Exhaust & Automotive Service Richmond, VA
Problem: Drive-ability
Service: Fuel pump, fuel filter, valve cover gaskets
Owner: Doug Boyer
Date: February 28th, 2014
Service: Miscellaneous parts, thermostat, gasket, water temp gauge, transmission temperature sender, oil and filter
Date: March 25th, 2014
Service: Viscous fan spinner, cylinder head bolt set, expansion tank, cap, gasket set
Date: July 14th, 2014
Mileage 180,218
Problem: CEL
Service: Upstream 02 sensor
Date: May 15th, 2015
Mileage: 183,567
Problem: Crankshaft seal leaking, motor mounts broken, rear hatch will not open,
Service: R&R crankshaft seal, exhaust gasket, all motor mounts, curfix seals on rear main, oil cooler O rings, power steering O rings, fuel line O rings, oil and filter change, exhaust manifold gaskets, down pipe studs.
Old Feb 1, 2017 | 10:14 PM
Mskembo's Avatar
I love the XD look. Great find and a great price!
Old Feb 10, 2017 | 12:32 PM
Bringing her home the first night
Straight to work
Realizing just how bent she was
Don't lie, you would have done it
Waking up the next morning, questioning my decision
Still unsure..
Dirty
Fancy plate
Fancy sticker
Back to work
Bro WTF did you hit
Stickers?
Nah
Brake controller?
Nah
CB?
Trailer plug?
Air system?
Nah
This was the first 12 hours of ownership, which also included vacuuming out dirt and dog hair (not shown)
Old Feb 10, 2017 | 03:55 PM
Looking good! Love that Camel Trophy look.
Old Feb 12, 2017 | 07:23 PM
Detoured Discovey's Avatar
1/2 rolled is a 'flop'.......not a roll.......
But cool any who.....
Old Feb 13, 2017 | 09:29 AM
Joe!'s Avatar
I've seen that truck before. Haha
Old Feb 14, 2017 | 09:21 AM
First mod was the Scangauge E which fits nicely in the ash tray location
Couple days later, test run to the Home Depot after changing the main fluids
Truck was gradually overheating
Pulled the radiator at night
Took a chance on a cheap eBay radiator
Grille notched and front end put back together with new Harbor Freight winch
Headliner came out and stayed out
Taking stock of my collapsed driver's seat, after paracord repair
That was really the only piece I wanted from my buddy's parts truck XD, somehow I ended up owning the whole vehicle...
Stripped
Buddy's yard..
Saying goodbye
Old Feb 15, 2017 | 07:57 AM
Gutted the interior
Installed the CB & Homelink
Added light guards
Drove her to work
Getting serious
Stripped the far bolt, had to cut a hole in the trans tunnel
Low range, check.
Added some safety gear
Almost ready for the first wheeling trip
Old Feb 21, 2017 | 10:14 PM
1/21/2017 - First wheeling trip in the Ocala National Forest: 150+ mile round trip over two days
Lined up along the pond
Traffic jam while we cleared a tree
Lunch break in front of the US Navy's Pinecastle Impact Range
Posing
Clay pit I assume was used for road construction
Rovering around with my buddies
I need lights
And jerry cans
Back at camp
Random hog dog we found the next day, returned to her owner
