Bad parts quality
That's total B$, but I can't say that I'm shocked seeing another Allmakes part that is a POS ![Poop](https://landroverforums.com/forum/images/smilies/1f4a9 (1).png)
They use the cheapest Made in China type vendors and slap the Allmakes name on it = NO THANKS!
If you want a belt that will last get a GATES. I've used Gates Belts on ALL my cars/trucks for years with zero issues.
And a headsup if you don't want to order one online, you can get Gates Belts at any NAPA.
They use Gates as their "private label" brand ( part numbers will start NBH...).
You have to be careful. Terrafirma /all makes is hit/miss with quality. Suspension stuff ships with no hardware and the rubber items don’t fit well. If the parts hold fluid or are a safety concern- there are other vendors that better quality than the China sourced stuff. Often times the real OEM stuff is on sale and is a better fit when installed.
Keep shopping and find the price and quality that works for you.
I had the Continental (?) Gatorback that some people swore was the best belt For a Disco 2. At 200 miles it started squealing and at 300 miles, a 2” wire started to stick out the side of the belt. I removed the gatorback belt (kept it in the truck as a back up belt) and bought a Dayco Poly Rib belt. After about 3000 miles it is still holding up.
alisaestmant
Member Group And Special Buys
11-07-2013 12:57 AM
