Is this ok? Rocker shaft tower pics
Old 09-24-2016, 03:06 PM
The_OGCJR's Avatar
Default Is this ok? Rocker shaft tower pics
So I'm doing a valve job and I ordered new rocker arms and shafts thinking I would reuse the rocker towers. As I cleaned them I found f one like this:
Those are pits in the aluminum. So, can I still use it? Why wouldn't you reuse it?
Old 09-26-2016, 09:38 PM
mr4x4's Avatar
are any of those pits more like burs? meaning they poke out and scratch the shaft
Old 09-26-2016, 10:05 PM
XCELLER8's Avatar
likely ok to reuse....the rocker shaft doesn't move in the towers...the bolts go thru both...just clean 'em up
Old 09-26-2016, 10:10 PM
mr4x4's Avatar
yeah xcellers right here a pdf showing how to line up the notches on the rocker arms to the rocker shaft in case you needed it.
It's from the engine rebuild manual.
File Type: pdf
The_OGCJR (09-27-2016)
Old 09-27-2016, 09:05 AM
The_OGCJR's Avatar
No burs. Just pits. I'm going to reuse on a new shaft with new rockers. Thank you for the pdf
Old 09-28-2016, 06:58 AM
mr4x4's Avatar
No problem I'm doing the same job. It turned out that alotvif the pin holes in the pushrods seats on the rocker arms were clogger up. I cleared them out and I hope it fixes my tick.
Old 09-28-2016, 01:27 PM
matt3502's Avatar
If that fixes your tick please post it! I think that is where my tick originates from.
Old 09-29-2016, 07:02 AM
mr4x4's Avatar
Yeah I really hope so. I should be putting the truck back together on Friday or Saturday. So I'll post if it fixes it then.
Old 09-29-2016, 08:41 AM
matt3502's Avatar
Roger that.
thehun
03-07-2013 01:35 AM
RezzaHD
03-05-2013 09:50 PM
nevada ben
07-17-2011 09:38 AM
thehun
06-02-2011 08:40 PM
mac25dm
09-04-2007 06:43 PM
Quick Reply: Is this ok? Rocker shaft tower pics
