Sights N Sounds Post Video and Sound clips here. This forum is for video's pertaining to Land Rovers, Range Rovers, and Freelanders.
Ticking noise and wandering idle
Old May 20, 2018 | 02:18 PM
Biz234's Avatar
7th Gear
Default Ticking noise and wandering idle
Just got this 97 disco 1 and there's a small ticking noise coming from the engine and a wandering idle.
the guy I bought it from said the engine had been replaced and so on, but I'm not sure what's going on..
The idle almost sounds like you are accelerating and then stopping to a normal idle..
Any ideas or suggestions as to what might be happening??
Old Jun 11, 2018 | 08:56 PM
CamelChad's Avatar
Can you post a video?
Old Jul 7, 2018 | 03:38 PM
mr. choodles's Avatar
Without hearing the sound, all bets are off. These cars tend to make a great range of noises, especially when neglected.
Old Jul 7, 2018 | 04:17 PM
CamelChad's Avatar
I had a similar issue. Turned out the manifold bolts to the Y-pipe were loose. Apparently it's pretty common. Should help with the tick. Idle issue is probably something separate all together.
Old Jul 8, 2018 | 10:21 AM
Biz234's Avatar
7th Gear
I'll take a look. Thanks!
yeah I bought it from a guy who got it at an auction, so who knows how neglectedl it has been.
Old Aug 14, 2018 | 10:11 PM
Dave03S's Avatar
Needing more info on the ticking, does the tick occur when you first start it up until it gets warm? Does it show up after it is up to temp and not while cold? Or is it present at all times? Does it go away with higher RPM's or get worse? And finally what oil are you using?
Jennyellen13
LR4
Feb 3, 2018 11:12 AM
94svt50
Mar 6, 2011 09:10 AM
David A
Feb 8, 2011 09:15 AM
jr99rover
Oct 24, 2010 09:34 PM
jck09
Apr 17, 2010 08:20 PM
