Tires What skins are you rollin' around on? Discuss wrapping your rims in here.
How Big Can I go?
Old Feb 4, 2008 | 08:45 PM
TheQ's Avatar
7th Gear
Default How Big Can I go?
I'm looking to get some bigger tires for my '02 Disco II. I don't really wantto do a lift. I also want to keep the 18" wheels. Anyone know how big I can go without rubbing?
Old Feb 5, 2008 | 04:00 PM
Default RE: How Big Can I go?
It is not even worth going to larger tires not only with the 18" wheels but without a lift. You truck has already settled an inch or more from when it came from the factory.
Old Feb 5, 2008 | 07:01 PM
LRDISCO's Avatar
You have to go with a smaller rim to fit mud tires but you cant go any bigger than stock i ditched the hurricanes for a set of black cragar rims and a set of 29X10.50X15 interco trxus sts a/t tires. The rims were 40 bucks a piece and the tires were 105. by the way the cragar rims makes the tires stick out alot wider maybe 4-5" and boy does it look mean. it makes it look like a land rover should
Old Feb 6, 2008 | 10:37 AM
You don't need to go to a smaller/narrower wheel just to step up in tire size.
Old Feb 9, 2008 | 06:33 PM
TheQ's Avatar
7th Gear
Thanks guys...you have changed my mind about not getting a lift. Now here's the thing, I can't seem to find lifts for a Disco II anywhere. Can anyone help with this? I'd like to go 2" with some 31's for tires.
devildollnyc
Jun 1, 2020 01:59 AM
kevlor80
Mar 2, 2017 10:37 PM
DrG3
Oct 5, 2010 09:09 PM
philhan
May 15, 2006 08:17 PM
